Syntec 6MA Z axis help
Results 1 to 2 of 2
Thread: Syntec 6MA Z axis help
    Member maynesy's Avatar
    Apr 2020
    Default Syntec 6MA Z axis help
    Hi all need some help, we have a Syntec 6MA controlled CNC and trying to be able to set z height to material surface per job
    1. lower z axis to material height
    2. apply machine coordinates on that axis - (xy axis work this way but not z)
    but it gives me a negative value in the G54P1(G54) setting and it alarms out if trying to run job,
    but if I set the height manually in the G54P1(G54) to material thickness it works
    is there a way to use apply machine coords
    thank any help greatly appreciated
    Member awerby's Avatar
    Apr 2004
    Default Re: Syntec 6MA Z axis help
    What happens when you set it to zero?
