Need Help! Richauto This is piracy ccontrol System?
Results 1 to 6 of 6
Thread: Richauto This is piracy ccontrol System?
    Sep 2021
    Default Richauto This is piracy ccontrol System?
    When i start it shows This Is Piracy Control System? It try'd to update software but no use its not showing anything on uDisk what should I Do?
    Attached Thumbnails Attached Thumbnails Richauto This is piracy ccontrol System?-img_20210923_091205-jpg
    Aug 2017
    China
    Default Re: Richauto This is piracy ccontrol System?
    it says that you used copy control card ,pls contact suppler .dsp exact mode and suitable update apk file.
    Sep 2021
    I also got same i have update file but it doesn't show files inside uDisk?
    Member gix's Avatar
    Nov 2020
    how did you manage to solve the problem? I'm in the same situation.
    Can you help me?
    Jun 2005
    Sounds like another Chinese company tried to clone the Richauto dip CNc controller and they have some firmware on board that prevents clones from working. Bet you do not have a real Richauto control. Send a detailed photo to Richauto company
    Aug 2017
    China
    it is better that show whole control panel .
    1 check if your countrol system is Rich auto .
    2 if you buy copy control system , contact suppler
    3 my suggest is that buy new original dsp control system ,such as A11 A18 etc . my whatsapp is +8618560201508
    Richauto This is piracy ccontrol System?-richauto-dspa11-jpg
    Attached Thumbnails Attached Thumbnails Richauto This is piracy ccontrol System?-richauto-dspa11-jpg
  7. #7
    Quote Originally Posted by allencncrouter View Post
    it says that you used copy control card ,pls contact suppler .dsp exact mode and suitable update gb whatsapp file.
    yes, thanks. I will do
