Need Help! CNC Stepper Motor Source
Results 1 to 3 of 3
Thread: CNC Stepper Motor Source
    Member OiUkes's Avatar
    Apr 2020
    Default CNC Stepper Motor Source
    Looking for a source for Chinese 6040 X & Axis Stepper Motors. Froze after a year, under "warranty" but no help from seller.
    NEMA 23 frame size 57mm x 76mm, 3A, 200 steps 1.8 degrees, 8 mm main shaft with a 6.35mm rear shaft for handwheel. Any info including correct Nm (oz-in) holding torque appreciated.
    Jan 2018
    United Kingdom
    Default Re: CNC Stepper Motor Source
    Quote Originally Posted by OiUkes View Post
    Been looking for an hour.
    Haven't found anything below 114mm length with 2 different shaft sizes.
    It's either change coupling or change handwheel.
    All I found so far:
    https://www.automationtechnologiesin...haft-with-flat
    https://www.automationtechnologiesin...flat-282-oz-in
    https://www.omc-stepperonline.com/ne...rice&order=ASC
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Hi Oik - Have you checked the motors? They very rarely die...Peter
