Work origin?
Limits are not for the work origin, they are for the MACHINE origin.
This is 2 different things.
You set the limits so an axis can't travel past it's ends in machine origin co-ordinates.
Your work origin co-ordinates are positioned by the user themselves.
Then. If you set a starting co-ordinate for a part that puts the part out of limit bounds it will tell you. You then need to reposition your part until it fits on the table space. The cross pretty much means nothing it just shows you where YOU have set the WORK co-ordinates on what the MACHINE thinks is the table size area relative to it's ends/limits. (that's IF you have set it up properly in the first place).
If the machine does not know where it is, you will always have problems.
You really need to do some hard reading / video watching of the cnc program you're using ie mach3 or other type, and know all of this properly.
