- NEED HELP! Spindle wont turn on
Re: NEED HELP! Spindle wont turn on
spindle dont work
1 spindle itself
2 VFD inveter
3 cable connection check
Check all the connections for tighness.
Is the relay pulling in? If not, is the relay getting a voltage to energise?
- You may not post replies
- You may not edit your posts
Forum Rules
