Need Help! Need help! CnC router Syntec 6MB alarm
Results 1 to 3 of 3
Thread: Need help! CnC router Syntec 6MB alarm
    Dec 2020
    Default Need help! CnC router Syntec 6MB alarm
    My company have a cnc router Syntec 6mb and an alarm error keep showing "MLC 84 (R45. 3) PLC Alarm"... The spindle is rotating just fine.. But the machine doesn't want to move..Anyone knows what is wrong with the machine? What should i do to solve this problem? Thanks
    Aug 2009
    Default Re: Need help! CnC router Syntec 6MB alarm
    Unfortunately not sure. I looked through the manual I had but error code mlc 84 is not listed so I guess it's a machine manufacturer added code.
    I'd check all the sensors you can think of. I had a weird one once where it was a loose sensor that reported that the tool changer was retracted.
    Good luck.
    Sent from my Pixel 3 using Tapatalk
    In case anyone is wondering, I'm the twin of the other gfacer on cnczone...
    Jan 2012
    Israel
    Quote Originally Posted by gfacer2 View Post
    Good luck.
    i have same error
    6mb also
