Looking to buy a CNC from china. Recommendations/Information?
Results 1 to 2 of 2
Thread: Looking to buy a CNC from china. Recommendations/Information?
    Default Looking to buy a CNC from china. Recommendations/Information?
    I'm looking to buy a CNC with the following features:
    1. 1300x2500mm minimum
    2. Automatic tool changer
    3. Vacuum table
    4. Rotary axis on long edge
    5. Dust collection system.
    Does anyone have any recommendations for Chinese companies that generally provide good machines?
    I'm not an expert with CNCs, and definitely not an expert on importing stuff, so if anyone could also provide me information for what I need to watch out for when negotiating, certain specifications to look out for, a good control system (syntec?) that works well with fusion 360 generated files, etc... that would be greatly appreciated.
    Thanks!
    Aug 2017
    China
    Default Re: Looking to buy a CNC from china. Recommendations/Information?
    1 1325 is popular for some standard 1220*2400mm MDF board , at same time,1325 1530 working area cnc save gantry move out trouble , when choose 2030 , as container inside width is 2250mm,gantry have to move out ,customer setup gantry again after recive cnc.
    2 Italy HSD 9kw ES951 24000rpm ISO 30 tool chuck +linear tool magainze is popular and easy to learn for new user.
    3 380v3 phase is better ,then you choose Germany Becker KVT3.140 vacuum pump ,140cbm/h , or China JQT brand dry rotary vane 5.5kw ,160cbm/h . have a better vacuum effect for 1325 vacuum area .
    if only have 220v1 phase , choose 2 to 3 pcs , China JQT 2.2kw vacuum pump.
    4 rotary on Y axis , do you want fixed rotary on frame ? you process sylinder wood or square wood ,then it need to known orign wood size .
    5 3kw or 5.5kw 2 bags is popular dust collector .
    6 Synetc control system support G code ,M code ,You need choose correct post processor ,or add post processor on computer .
    If you have any question ,add my whatsapp +8618560201508
