CNC 6040 connection FI MK100-2S1.5G-DK to mainboard JP-3163B cabling question - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
Thread: CNC 6040 connection FI MK100-2S1.5G-DK to mainboard JP-3163B cabling question
  1. #21
    Default Re: CNC 6040 connection FI MK100-2S1.5G-DK to mainboard JP-3163B cabling question
    in side the VFD, jumper and posts
    Like this..
    Attached Thumbnails Attached Thumbnails CNC 6040 connection FI  MK100-2S1.5G-DK to mainboard JP-3163B cabling question-img_0477-jpg   CNC 6040 connection FI  MK100-2S1.5G-DK to mainboard JP-3163B cabling question-img_0277-jpg   CNC 6040 connection FI  MK100-2S1.5G-DK to mainboard JP-3163B cabling question-img_0479-jpg   CNC 6040 connection FI  MK100-2S1.5G-DK to mainboard JP-3163B cabling question-img_0495-jpg
    CNC 6040 connection FI  MK100-2S1.5G-DK to mainboard JP-3163B cabling question-img_0496-jpg
  2. #22
    Member S3V3N's Avatar
    Oct 2020
    Hallo Raini,
    Ich habe exakt das gleiche Problem wie du. Ich betreibe die Maschine mehr schlecht als recht mit estlcam. Hast du das Problem gelöst
    mit dem VFD? Ich blicke hier nicht ganz durch mit der Verkabelung und diesem Zusatzteil (Converter) Wo wird der eingebaut und verkabelt?
    Kannst du mir das erklären?
    Gruss Tom
  3. #23
    Sep 2010
    england
    Hey there, I have this same unit which came wiht my CNC6040 i bought second hand but the VFD is locked in password mode, does anyone know the password for them?
  4. #24
    Jan 2005
    Quote Originally Posted by craigrobbo View Post
    It will depend if someone has added a pass word but normally people should not
    This will also depend on what VFD Drive you have also
    Check Parameter PD000=0 if set to 1 that will lock parameter setting this is for the HY VFD Drive
    Mactec54
