- NCstudio - access in the parameters
i'm from brazil, i bought a CNC that came with the NCstudio program.
need to change parameter 4050 - Tool Raising Height On Pause
to 0mm
for that I need to access the configuration parameters.
the program is version 5.6.60 and I cannot access the "Parameter Configuration"
the option does not appear in the menu, how to solve?
attached menu image
Re: NCstudio - access in the parameters
Try ncstudio for password. If that doesn't work let me know. I have it documented somewhere.
this password is used to access the "Params -> Manufactory" tab
what I need to access is according to the image below ... you can see that I don't have this option in the menu.
- You may not post replies
- You may not edit your posts
Forum Rules
