Need Help! CNCEST
Results 1 to 10 of 10
Thread: CNCEST
    Jul 2015
    Default CNCEST
    I am in need of some help, I bought a 6040 cnc router and need the drivers (i think)to get this up and running. it's been in my shop for 4 months and wont do a thing.....I can turn the knobs on the stepper motors with power off, but when you turn the controler on the motors lock up.....I bought a faster computer with windows 7 installed ( as per the seller) also a new monitor, remote control for mach 3..........I need to get this running..... thank you for any help you can offer.
    Member routalot's Avatar
    Dec 2003
    Default Re: CNCEST
    From the description it seems that the motors are doing what they should.They are intended to remain in place with a current applied and to move when the controller sends them a number of pulses.Have you been through the Mach 3 parameters to make sure they are correct?Do you have a sample Gcode file that can be run to verify that the machine will actually run?
    Jul 2015
    Default Re: CNCEST
    no G code yet,,I am a old dog, and slow with new tricks, but learning fusion 360, slowly The block pops up with the message " Driver not found" I will find some code to run.
    Member machinehop5's Avatar
    Aug 2009
    Default Re: CNCEST
    Quote Originally Posted by Broken View Post
    ... attach/upload some photos...and screen shots of your System may help us.
    Dec 2012
    Mexico
    Default Re: CNCEST
    Hello.
    As far as i know the drivers are already part of the MACH3 system but for certain generic breakout cards only.
    While it´s not clear enough MACH3 appears to be a 32 bit application. Have you checked both your Windows and MACH3 versions?
    Also check for your breakout card. It might need the drivers you mentioned and they should be asked to the breakout card manufacturer not ARTSOFT although they might help.
    Hope this helps.
    Regards.
    Dec 2012
    Mexico
    Default Re: CNCEST
    Addendum.
    Check for the existance of the following drivers in your WINDOWS\SYSTEM32\DRIVERS folder:
    parport.sys
    serenum.sys
    serial.sys
    MACH3 is supposed to use the corresponding driver.
    Regards.
  7. #7
    Dec 2003
    Default Re: CNCEST
    I wonder if the Mach 3 that was supplied is the full version or one of the fabled pirate or demo versions.Either way, I suspect the original question would find an answer faster on the dedicated Mach software forum https://www.cnczone.com/forums/mach-...oft-software-/ .
  8. #8
    Jul 2015
    Default Re: CNCEST
    thanks
  9. #9
    Jul 2015
    Default Re: CNCEST
    they are there, do I need to copy them into Mach3 ?
  10. #10
    Member number40Fan's Avatar
    Nov 2019
    Default Re: CNCEST
    The copy of Mach3 that came with mine was a pirated version.
    This is the RNRMotion.dll file that got me going.
    Attached Files Attached Files
CNCEST
CNCEST
