USA Client Teach You Use DSP Handhold Cnc Control System
Cnc router new user learning DSP in Omni factory
hallo guys ,
i have CNC machine with DSP controller , i already set g codes reading from software (i use aspire) everything works fine .
i cant find how i can change speed between cuts (from one to another travel speed) i change it in software (rapid rate)but nothing happens , it goes very slow from one cut to another....
If your control system is A1X,you can follow this friend,hope it could be helpfull for you
Machine parameter-maximum speed setting: This parameter is the maximum setting of processing speed, does not affect the speed of manual movement XYZ
After selecting the target processing file and pressing the "OK" key, the user can modify the processing parameters, including processing speed, dry running speed, speed override, and knife drop override. According to your description, the empty line speed setting is too low, resulting in a slow movement from one cutting pattern to another cutting pattern. You can modify the processing parameters before processing
In the process of processing, you can control the magnification change of the processing speed by pressing "Y+" "Y-", the magnification change is between 0-1, and the magnification change is 0.1 each time
just feel free to cantact me ,whatsapp number is+86 17824821877.
Our company has been established for seven years.i can offer you good choices
