That looks pretty bad. I would be concerned about how much support structure there is under the phenolic top. Were the CNC mine, I would look to supplement what structure is already there. If you machine it as is, you might not have enough gasket groove depth to allow the gasket to fully compress under vacuum in certain areas. See if the company would send a replacement top. I wouldn't trust the one you have.
