Need Help! Burned resistor
Results 1 to 3 of 3
Thread: Burned resistor
    Jun 2020
    Unhappy Burned resistor
    Hi!
    I bought one of the nice colored tan CNEST machines with PRT-E1500W controller. After configuring it according to helpful threads in this forum I started a test run, and after a minute or two I smelled something burnt and the spindle stopped.
    After opening the machine I saw what I think is a resistor that seems to be blown.
    I have contacted the seller, but in the mean time I thought to see if someone else have had this problem (couldn't find anything with google search). And possible if someone have the same controller they could measure the resistor so i can replace it.
    Jun 2020
    Default Re: Burned resistor
    I failed to include the images in the previous post. Including them here.
    Attached Thumbnails Attached Thumbnails Burned resistor-cnc1-jpg   Burned resistor-cnc2-jpg
    from the location on the board I would guess that is the pre-charge resistor.
    When you first connect the power the power supply capacitors are discharged and there is a HUGE in-rush of current to charge them up, the
    in-rush is that much it usually pops the fuse. To overcome this a resistor of commonly several hundred Ohms is inserted in the capacitor circuit
    and that resistor will limit the charge current such that the fuse does not blow. After a second or so the capacitors are charged and so the resistor can be by-passed
    without risk to the power supply fuse. If the pre-charge relay (or IGBT or MOSFET or SCR or whatever...) does not close after the pre-charge interval
    then the drive load current will have to pass via the pre-charge resistor with the result that it burns up.
    You need top establish if it is the pre-charge resistor, as I suspect and second, what device or mechanism is used to bypass the resistor....because if that
    device has failed then your new resistor will last no longer than the original.
    Craig
Burned resistor
Burned resistor
Burned resistor
