New here .. help with Chinese 6040 router / mill ?
Results 1 to 4 of 4
Thread: New here .. help with Chinese 6040 router / mill ?
    May 2020
    Default New here .. help with Chinese 6040 router / mill ?
    Hi , sorry if this is in the wrong spot -
    I have a Chinese 6040 cnc mill mainly used for wood projects - want to add a touch plate for zeroing on a axis .. watch all tutorials online but they all say ‘ once you find where to wire it into you should see xxx on the screen ‘
    Well , I can’t find where to wire it into ... can someone please help with where to wire into and port settings - mine is the USB model not parallel model .. here are the boards inside the main controller
    Attached Thumbnails Attached Thumbnails New here .. help with Chinese 6040 router / mill ?-bbfa40fe-8a1a-4c98-83e4-3e78ec97ea25-jpg   New here .. help with Chinese 6040 router / mill ?-b1988adf-8416-4d5b-9634-d17ed8e0b668-jpg   New here .. help with Chinese 6040 router / mill ?-4bfa3104-12ae-4cbd-94f8-131f3615dd27-jpg   New here .. help with Chinese 6040 router / mill ?-71237b49-d5aa-45da-a208-b48f453bf9b6-jpeg
    May 2020
    Default Re: New here .. help with Chinese 6040 router / mill ?
    EDIT- meant to read Z axis’s ... NOT A (spell check took over )
    Jan 2018
    United Kingdom
    Looks like this one:
    https://www.alibaba.com/product-deta...667911945.html
    No gurantees though.
    May 2020
    Quote Originally Posted by dazp1976 View Post
    Thanks dazp1976 ..... that worked , I just had the wrong input ????
