Need Help! CNCEST 6040 - milling problem when router have to change rapidly the direction
Results 1 to 1 of 1
Thread: CNCEST 6040 - milling problem when router have to change rapidly the direction
    Unhappy CNCEST 6040 - milling problem when router have to change rapidly the direction
    Hi guys! I have a 6040 CNC-EST. Cam used is RhinoCAM. 95% of work on that machine is "profiling".
    I faced a serious problem when the router has to follow small path that are at right angle.
    Instead of having 90 deg cut I got inclined cuts.
    I already lowered the acceleration as much as possible, but the result is always the same. Obviously the acceleration value is the same on all axis. Cut method is always "conventional cut".
    Feed speed is 1800 mm/min and spindle speed is 18000 with a mill bit of 1.5 mm.
    I attached cam preview and what I got.
    What could be the problem?
    Thanks to everybody can contribute to solve this problem
    Cheers
    Alex
    CNCEST 6040 - milling problem when router have to change rapidly the direction-89830185_10221974391011715_7900333109650915328_n-jpg
    CNCEST 6040 - milling problem when router have to change rapidly the direction-89834540_10221974397731883_5077728105058009088_n-jpg
    CNCEST 6040 - milling problem when router have to change rapidly the direction-90049735_10221974400171944_2432651355987378176_n-jpg
    Attached Thumbnails Attached Thumbnails CNCEST 6040 - milling problem when router have to change rapidly the direction-89830185_10221974391011715_7900333109650915328_n-jpg   CNCEST 6040 - milling problem when router have to change rapidly the direction-89834540_10221974397731883_5077728105058009088_n-jpg   CNCEST 6040 - milling problem when router have to change rapidly the direction-90049735_10221974400171944_2432651355987378176_n-jpg
