CNC 3018: laser & drill not turning on
Results 1 to 2 of 2
Thread: CNC 3018: laser & drill not turning on
    Member another_dave's Avatar
    Feb 2020
    Default CNC 3018: laser & drill not turning on
    Hi All,
    I have purchase a 3018 CNC engraver off eBay but having difficulty getting either the laser or drill to turn on. The X,Y & Z axes move fine but I can't burn or engrave.
    Below are the following steps tried:
    I have 2 CNC 3018 machine which are different makes and one of which functions fine using the same computer & software installed.
    Taken the laser from problem device and plugged into known good machine which doesn't work
    Taken known good laser from working machine and plugged into problem machine which doesn't work
    Taken drill from problem device and connected to know good machine which works fine
    Taken drill from known good machine and plugged into problem one and it doesn't work
    LiteFire v1.25.82.2040
    When I click "laser on (Strong)" I see an LED turn on from the board but the laser itself doesn't turn on
    grblControl v0.8.4
    When I press the "spindle off / on" button nothing happens
    Problem model
    Woodpecker board
    Purchased here: https://www.ebay.co.uk/itm/401825435448
    Working model
    Purchased here: https://www.amazon.co.uk/dp/B07VCV18..._mLysEbJNK18E4
    Feb 2020
    Default Re: CNC 3018: laser & drill not turning on
    Please can someone delete this duplicate thread. I don't seem to have to option to do so myself.
