z axis switch doesn't work on homing
Results 1 to 2 of 2
Thread: z axis switch doesn't work on homing
    shelk's Avatar
    Feb 2020
    Default z axis switch doesn't work on homing
    i've purchased and assmebled a generic 3018 chinese CNC
    i've added limit switches, and changed the settings, hard limits are on, and all switches work without any issue
    the problem is homing, when i try homing, z axis goes up and the switch doesn't make it stop and just keeps spinning
    Thanks in advance for any help
    Member gp1200ss's Avatar
    Aug 2020
    Default Re: z axis switch doesn't work on homing
    If you are using latest firmware, i had issues with woodpecker board, to use homing i bought an MKS DLC. some pins on arduino clones were repurposed in later grbl versions....
