Newbie x axis needs mirror
Results 1 to 3 of 3
Thread: x axis needs mirror
    Member backmailingbox's Avatar
    Dec 2019
    Default x axis needs mirror
    Hi, I have a chinese 4030T device. Now I have a problem that picture in software (only x axis) needs mirroring. I am using CNC USB Controller
    Y is OK, Z is OK, but x needs mirroring. I can not see any setting for it... any help?
    Member awerby's Avatar
    Apr 2004
    Default Re: x axis needs mirror
    The easiest thing to do would be to flip the drawing in your CAD software and regenerate the toolpath in CAM. If that won't work for some reason, you could change the direction bit for the X axis, but you'd have to remember that everything's backwards now, and to change it back when this job is done.
    Dec 2019
    Yes thanks, I solved the problem
x axis needs mirror
x axis needs mirror
