I have a Syntec 6MB controller and I want to change a parameter outside the allowable range. The parameter is 3411, and this is parameter is the distance between the cutting bed surface and the tool probe position. The input range is limited to + or - 65535, or 65.5mm. I want to install a new taller tool probe, with a greater offset that is currently permitted. Could anyone guide me on editing the input range for this parameter?
