3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM - Page 5
Page 5 of 5 FirstFirst ... 2345
Results 49 to 53 of 53
Thread: 3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM
  1. #49
    Member john-100's Avatar
    Mar 2007
    uk
    Default Re: 3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM
    the C22 board has the advantage of having the 2 buffer IC's
    and terminals making it easier to connect the 5V supply to the MPG
    John
    PS
    if you take 5V from a USB socket
    3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM-usb-power-cable-jpg
    3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM-usb-pinout-jpg
  2. #50
    Member Michael82's Avatar
    Nov 2007
    Quote Originally Posted by john-100 View Post
    John
    PS
    John after doing as much research I can stand I have not found anyone that has wired their mpg directly to the printer port without a c22 board . I dont have a c22 board so I have to try and do this without it ....or buy one .... so could I use an outside 5v power source for the 5v and the 0v and use the rest of the pins as shown in the pinout ??
  3. #51
    Nov 2007
    Quote Originally Posted by Michael82 View Post
    Hey john what about getting the 5 volts from the PC's power supplys disk driver cable would that work??
  4. #52
    Mar 2007
    uk
    a USB cable as in post 49 is an easy solution that enables you to just plug into an existing external socket
    25pin D-type plug and USB plug to MPG cable
    if the USB cable joint is hidden inside the D-type shell
    the USB cable can be held under the clamp with the MPG cable
    ( use heatshrink sleeving to insulate the joint )
    the LED indicator can be wired to the 5V supply
    3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM-mpg-wiring-d-type-usb-jpg
    yes you can connect the MPG to a PC power supply black 0V wire and red +5V wire ( not the yellow + 12V wire !!!! )
    you can either use a 4 pin molex connector or 15 pin SATA connector as used on internal disk drives and then thread the cable through the PC case
    3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM-mpg-pulse-generator-4-pin-molex-jpg
    John
    Last edited by john-100; 12-12-2019 at 07:43 PM. Reason: add mpg to 25 pin D type + USB diagram
  5. #53
    Nov 2007
    John
    I like that setup you have posted rather than the 1 I suggested and I have that exact db25 connection too!
