3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM - Page 3
Page 3 of 5 FirstFirst 12345 LastLast
Results 25 to 36 of 53
Thread: 3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM
  1. #25
    Member Michael82's Avatar
    Nov 2007
    Quote Originally Posted by john-100 View Post
    Yes
    That BOB will be easier with the screw terminals to connect to
    Attachment 431332
    I would still use the larger 1XHCEL Board relay to keep the mains away from the BOB !!!!
    Attachment 431334
    PS
    2nd BOB to 1XHCEL relay board
    Attachment 431338
    Attachment 431336
    John
    Hey John I ordered the 1 relay switch it will be here in a week or so
  2. #26
    Member john-100's Avatar
    Mar 2007
    uk
    Default Re: 3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM
    have you connected one axis to the BOB or all three?
    the 6th photo in post 3 shows a 3 pin connector on your stepper driver
    so you just step direction and common - not sure if its 0V or +5V *** update see PS its +5V
    do you have a cable with the original 5 pin connector that plug into the original BOB ?
    if the 3 wires connected to the centre 3 connections the common was the BOB's 0V
    assuming the diagram in post 18 is correct
    have you re assigned the printer port pins 2 to 9 in mach3's pins and ports ?
    the step & direction pin assignment is different for the 2 BOB's !!!!
    John
    PS
    TX14207 step & direction connections
    3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM-tx14207-step-dir-connections-jpg
    TX14207
    3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM-tx14207-jpg
    Last edited by john-100; 11-17-2019 at 07:40 PM. Reason: add PS TX14207 step , direction connections
  3. #27
    Nov 2007
    John
    PS
    TX14207
    I got all 3 boards connected there is a 3 pin plug on the driver side and a 4 pin on the bob side , I had a few problems getting them working but they all work on the new 5 axis bob . I was gonna ask what do I need for a manual pulse generator to work with this setup??
  4. #28
    Mar 2007
    uk
    " what do I need for a manual pulse generator to work with this setup ? "
    If your talking about a MPG like this
    3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM-mpg-jpg
    which contains a rotory quadrature encoder
    and switches to select
    1 of 6 axis
    1 of 3 step size
    E stop
    for this type of simple MPG you need a second parallel printerport or a USB / Ethernet control board emulating a second printer port
    John
    PS
    circuit of MPG
    3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM-mpg-circuit-png
  5. #29
    Nov 2007
    1 of 6 axis
    1 of 3 step size
    E stop
    John
    PS
    circuit of MPG
    Yes that is exactly what I'm talking about ... thanks john u have been a big help I will let you know when I fr et the relay switch in and hooked up
  6. #30
    Nov 2007
    1 of 6 axis
    1 of 3 step size
    E stop
    John
    PS
    circuit of MPG
    Hey john I know this is a stupid question but I dont know enough about electronics to know I have a firewire(ieee1394) port on the back of my hp desktop that mach3 and my cnc controller box is running from . My question is can I use the firewire port for the manual pulse generator like the one in the picture you posted or is this port for something else
  7. #31
    Mar 2007
    uk
    with a breakout board like this that has a USB connection for a 5V supply connection - not data !!!!
    3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM-20191114_181750-jpg
    you either need a PC with 2 parallel printer ports
    or a motion controller like a smooth stepper connected via a USB port or ethernet port
    that emulates 2 printerports
    I can't think of a control using a fire wire
    As I am off to Portugal early tomorrow (sunday)
    to see Postmodern Jukebox
    3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM-pmj-estoril-jpg
    Its going to be friday before I can reply again as I'm only taking a dumb phone
    John
  8. #32
    Nov 2007
    John
    Have fun look forward to hearing from u then
  9. #33
    Dec 2003
    East Anglia,England
    I can understand the satisfaction that will be a part of completing this process and achieving a goal.On the other hand it does seem like a lot of work to avoid the need to flip a switch and get cutting.If the anticipated projects include something like producing lithophanes and leaving the machine unattended for hours before it switches itself off,it will be totally justified.If the planned projects are limited to cutting out wing ribs for model aircraft and a cutting sequence that last maybe four minutes it gets harder to justify the time away from the activity that the machine was bought for unless machine modification is the new primary interest.
  10. #34
    Nov 2007
    Quote Originally Posted by Michael82 View Post
    Hey John am I gonna have to download a plugin for mach3 for this manual pulse genarator ? https://www.ebay.com/itm/CNC-Handwhe...k/173086400502
  11. #35
    Nov 2007
    Hey john how was the show??? Hope all is well I got the relay in and I'm about ready to start wiring it up .
  12. #36
    Mar 2007
    uk
    Hi Michael82
    A great time had by all
    The show and to seeing Sara Niemietz singing live was great
    going by the response of the Portugese audiance I expect PMJ will return to Portugal
    youtube clip with Sara from august
    The parts of Portugal we visited was nice as was the Portugese people
    Being the front seat passenger of a taxi being driven on the wrong side of the road was unnerving
    ( from my point of view the world is wrong driving on the right ! )
    We all ready have tickets for PMJ in september 2020 at the Royal Liverpool Philharmonic , which is closer to home !
    https://www.liverpoolphil.com/
    How are you connecting the MPG via a second printerport ?
    something likes this ?
    https://cnc4pc.com/Tech_Docs/guide_f..._over_LPT2.htm
    John
