3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM - Page 2
Page 2 of 5 FirstFirst 12345 LastLast
Results 21 to 40 of 100
Thread: 3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM
  1. #21
    Member Michael82's Avatar
    Nov 2007
    Quote Originally Posted by Michael82 View Post
    It is a 3 axis machine ....and yes I do have a multimeter...what do I check
    What do I set the multimeter on and where on the bob do I check the moto??
  2. #22
    Member john-100's Avatar
    Mar 2007
    uk
    Default Re: 3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM
    if your not using the 4th axis
    this is one possible way of using the "clock" signal from the printer port pin 2 assuming the BOB schematic is correct
    3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM-relay-board-connections-axis-jpg
    looking at the schematic of the BOB showing the motor connector
    3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM-bob-motor-connector-jpg
    if the schematic is correct
    with your multimeter set to continuity / low ohm range
    you should find one of the "moto " connector pins is connected to the BOB ground / - 24V supply
    the second pin goes to Printer Port pin 1 and one of the 330 ohm resistors in the resistor network
    3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM-bob-top-v2-jpg
    if the moto connector is as shown
    then you will have +5V connected via 330 ohm resistor on the BOB
    to the LED within the opto-isolator on the relay board and it's 4700 ohm resistor ( if I have read the value off the photo correctly) then to ground / 0V
    3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM-1xhcel-relay-board-jpg
    John
  3. #23
    Nov 2007
    Quote Originally Posted by john-100 View Post
    John
    Would this bob help
    Attached Thumbnails Attached Thumbnails 3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM-20191114_181750-jpg   3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM-20191114_181735-jpg
  4. #24
    Mar 2007
    uk
    Yes
    That BOB will be easier with the screw terminals to connect to
    3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM-ebay-cnc-bob-2-jpg
    I would still use the larger 1XHCEL Board relay to keep the mains away from the BOB !!!!
    1XHCEL Board Datasheet.pdf
    PS
    2nd BOB to 1XHCEL relay board
    3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM-relay-board-connections-2nd-bob-jpg
    3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM-1xhcel-connections-jpg
    John
    Last edited by john-100; 11-15-2019 at 03:44 PM. Reason: add PS revised 2nd BOB to 1XHCEL relay board connection
  5. #25
    Nov 2007
    Yes
    PS
    John
    Hey John I ordered the 1 relay switch it will be here in a week or so
  6. #26
    Mar 2007
    uk
    have you connected one axis to the BOB or all three?
    the 6th photo in post 3 shows a 3 pin connector on your stepper driver
    so you just step direction and common - not sure if its 0V or +5V *** update see PS its +5V
    do you have a cable with the original 5 pin connector that plug into the original BOB ?
    if the 3 wires connected to the centre 3 connections the common was the BOB's 0V
    assuming the diagram in post 18 is correct
    have you re assigned the printer port pins 2 to 9 in mach3's pins and ports ?
    the step & direction pin assignment is different for the 2 BOB's !!!!
    John
    PS
    TX14207 step & direction connections
    3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM-tx14207-step-dir-connections-jpg
    TX14207
    3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM-tx14207-jpg
    Last edited by john-100; 11-17-2019 at 07:40 PM. Reason: add PS TX14207 step , direction connections
  7. #27
    Nov 2007
    John
    PS
    TX14207
    I got all 3 boards connected there is a 3 pin plug on the driver side and a 4 pin on the bob side , I had a few problems getting them working but they all work on the new 5 axis bob . I was gonna ask what do I need for a manual pulse generator to work with this setup??
  8. #28
    Mar 2007
    uk
    " what do I need for a manual pulse generator to work with this setup ? "
    If your talking about a MPG like this
    3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM-mpg-jpg
    which contains a rotory quadrature encoder
    and switches to select
    1 of 6 axis
    1 of 3 step size
    E stop
    for this type of simple MPG you need a second parallel printerport or a USB / Ethernet control board emulating a second printer port
    John
    PS
    circuit of MPG
    3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM-mpg-circuit-png
  9. #29
    Nov 2007
    1 of 6 axis
    1 of 3 step size
    E stop
    John
    PS
    circuit of MPG
    Yes that is exactly what I'm talking about ... thanks john u have been a big help I will let you know when I fr et the relay switch in and hooked up
  10. #30
    Nov 2007
    1 of 6 axis
    1 of 3 step size
    E stop
    John
    PS
    circuit of MPG
    Hey john I know this is a stupid question but I dont know enough about electronics to know I have a firewire(ieee1394) port on the back of my hp desktop that mach3 and my cnc controller box is running from . My question is can I use the firewire port for the manual pulse generator like the one in the picture you posted or is this port for something else
  11. #31
    Mar 2007
    uk
    with a breakout board like this that has a USB connection for a 5V supply connection - not data !!!!
    you either need a PC with 2 parallel printer ports
    or a motion controller like a smooth stepper connected via a USB port or ethernet port
    that emulates 2 printerports
    I can't think of a control using a fire wire
    As I am off to Portugal early tomorrow (sunday)
    to see Postmodern Jukebox
    3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM-pmj-estoril-jpg
    Its going to be friday before I can reply again as I'm only taking a dumb phone
    John
  12. #32
    Nov 2007
    John
    Have fun look forward to hearing from u then
  13. #33
    Dec 2003
    East Anglia,England
    I can understand the satisfaction that will be a part of completing this process and achieving a goal.On the other hand it does seem like a lot of work to avoid the need to flip a switch and get cutting.If the anticipated projects include something like producing lithophanes and leaving the machine unattended for hours before it switches itself off,it will be totally justified.If the planned projects are limited to cutting out wing ribs for model aircraft and a cutting sequence that last maybe four minutes it gets harder to justify the time away from the activity that the machine was bought for unless machine modification is the new primary interest.
  14. #34
    Nov 2007
    Hey John am I gonna have to download a plugin for mach3 for this manual pulse genarator ? https://www.ebay.com/itm/CNC-Handwhe...k/173086400502
  15. #35
    Nov 2007
    Hey john how was the show??? Hope all is well I got the relay in and I'm about ready to start wiring it up .
  16. #36
    Mar 2007
    uk
    Hi Michael82
    A great time had by all
    The show and to seeing Sara Niemietz singing live was great
    going by the response of the Portugese audiance I expect PMJ will return to Portugal
    youtube clip with Sara from august
    The parts of Portugal we visited was nice as was the Portugese people
    Being the front seat passenger of a taxi being driven on the wrong side of the road was unnerving
    ( from my point of view the world is wrong driving on the right ! )
    We all ready have tickets for PMJ in september 2020 at the Royal Liverpool Philharmonic , which is closer to home !
    https://www.liverpoolphil.com/
    How are you connecting the MPG via a second printerport ?
    something likes this ?
    https://cnc4pc.com/Tech_Docs/guide_f..._over_LPT2.htm
    John
  17. #37
    Nov 2007
    Hi Michael82
    John
    Hey john yes I'm gonna use a 2nd printer port I have installed it already and i have wired the mpg according to the instructions...they r different than what was in the picture from that post u linked in the comment is that ok??
  18. #38
    Nov 2007
    Well that helped alot john thanks I will get started on all this I have alot to do
  19. #39
    Mar 2007
    uk
    As I don't know what instructions you are looking at
    I suspect you wil have a wiring diagram for the MPG showing the Incremental encoder and the various switches connected to a 25 pin D-type connector
    you will need either an adaptor cable or interface for the
    connections between MPG and printer port
    the switches will connect an input to your printerport 2 to ground
    the input functions being assigned in pins and ports
    the Incremental encoder will need a +5V supply so not all MPG wires go to the 2nd printer port !
    the ground and the A & B outputs go to the printer port input
    I'll need to check but I think CNC4PC make an interface that will help to protect the incremental encoder
    John
    PS
    GUIDE FOR SETTING UP MPG2/3/4 OVER LPT2 USING MACH3 makes ref to C22
    C22 - Pendant Interface Card
    https://www.cnc4pc.com/c22-pendant-interface-card.html
    https://www.cnc4pc.com/pub/media/pro...ser_manual.pdf
  20. #40
    Nov 2007
    John
    PS
    This is what came with the manual pulse generator and ofcourse I cant read Chinese so I compared the front ( the pic in english) to the back the one in Chinese. This is what I had to go off of does it look right?
    Attached Thumbnails Attached Thumbnails 3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM-15758483001578802433085635266777-jpg   3040-T ROUTER MAKING SPINDLE TURN ON /OFF WITH PROGRAM-15758483511456978247053781267089-jpg
