Newbie iGolden CNC - buying machine from China, are these components good? Please advise!
Results 1 to 6 of 6
Thread: iGolden CNC - buying machine from China, are these components good? Please advise!
    Member arepin78's Avatar
    Nov 2019
    Default iGolden CNC - buying machine from China, are these components good? Please advise!
    Greetings CNC Fellowship!
    My name is Geochi,
    I am setting up a workshop here in Spain (I moved from the States 2 years ago), and am looking to purchase a CNC machine from China. Have found the iGolden CNC on AlieExpress and have been in communication with their rep on WhatsApp. He has been quite helpful.
    The machine I was looking to get was a variation on this one - https://www.igoldencnc.com/woodworki...tary-axis.html
    The agent (he calls himself Benson) - provided me with the major components list and the manufacturer names. Would anyone please give me some feedback what it is I am dealing with quality wise and what can I expect:
    main components list:
    1.spindle:9kw HQD brand air cooling tool changer spindle
    2.Motor :Import Yaskawa(brand) servo motor and driver
    3.Guide rail:Taiwan HIWIN(brand) square guide rail
    4.Ball screw:German TBI(Brand) ball screw
    5.Gear:Taiwan XINYUE(Brand) rack pinion
    6.Control system:Taiwan LNC(brand) control system
    7.Inverter:China Fuling(brand) brand inverter
    8.Vacuum pump:China Tengyi(brand) vacuum pump
    9.Electric part::world famous CHINT(brand) electric parts
    Has anyone dealt with iGolden CNC and their machines by any chance?
    Aug 2017
    China
    Default Re: iGolden CNC - buying machine from China, are these components good? Please advise
    if budget is enough, Italy HSD9kw air cooling spindle and Germany Becker pump is also a nice choice.
    Mar 2017
    China
    You can choose the ABBA(brand) square guide rail for your machine. and Germany Becker vacuum pump if budget enough.
    Nov 2019
    Thank you for the suggesions - could you please explain as to why you think these are better (especially the square guide rail, as it was not even mentioned in the list I noticed)?
    Mar 2017
    China
    just a suggestion to get a good machine.
    you can e-mail me, I will explain for you.
    jnuniontech@gmail.com
    uniontech-andy@mail.ru
    Nov 2016
    China
    the machine you need depends on what kind of product you will process, more machine you can check: China High Speed CNC Router, CNC Machine, CNC Machine Center Manufacturers and Suppliers - Best Price Laser Cutting Machine for Sale - FANCH Machinery
  7. #7
    Nov 2019
    Good afternoon. The first obvious advantage of using CNC machines is a higher level of production automation. Cases of intervention by the machine operator in the manufacturing process of the part are minimized. I took parts from china. I even took a loan for them. They helped me do this here https://fnews.today/. Everything works. Good luck.
  8. #8
    michael_lu's Avatar
    Sep 2019
    JINAN
    You can choose to replace the latest machine
    Supply Forever Global Industry Co., Ltd.:https://www.supplyforever.com/
  9. #9
    Nov 2019
    I can mail you?
