Hi there guys
I would like to add some more tool holder positions to my machine and adjust the height offset for the tool holders as Im wanting to mount a much better dust collector foot wich requires adjustment height of the tool parking positions.
I currently have 6 positions but I know it could handle at least 4 more tool spots
So my Q would be to do with re configuring the tool park position machine commands??
Has anyone tried this before ?
Syntec Controler
Any help would be greatly appreciated.
Thx for that tip joey666
I did change that parameter 3409 now to 12 from the original 6 as I have built up the linear tool rack to handle 12 tools
The machine now responds to the additional tool positions
Only thing is that it seems to travel in the wrong tool park direction for T7 but seems to be happy with T8, but with T9,T10,T11 & T12
all it does is stay in the one position and goes through the release and clamp a tool process move.
Keep in mind that I have already adjusted and added the X,Y,Z for the additional tool holder positions in the global variable parameters starting from Parameter 600 onwards
Seems there is more parameter tool macro settings somewhere that need to be tweeked ??????
So if you are trying to enable additional tools too then we are in the same boat with this one.
I think that has to do wih the T0000 macro tool 9-12 are not defined. Can you share your full backup?
Can you add T9-12 to ATC INFO screen, thats what i can not change higher then T10.
