GRBL 1.1 Cutting arc on the Z-axis using G2 command?
Results 1 to 5 of 5
Thread: GRBL 1.1 Cutting arc on the Z-axis using G2 command?
    Member kevinol's Avatar
    Oct 2019
    Default GRBL 1.1 Cutting arc on the Z-axis using G2 command?
    I have a piece I need to cut a 180 circle out of in the Z-axis. From what I've read, this would be supported by something like this...
    G91
    F100
    G2 X0Y0Z0 I0 J0 K-2
    But when I run that, all I get is "OK" back without movement. Any ideas?
    Aug 2009
    Default Re: GRBL 1.1 Cutting arc on the Z-axis using G2 command?
    You have asked for a circle with zero radius. The arc commands work by moving to the start point, then in the g2/g3 command specifying the end point, and specifying the incremental distance in I and J words. Grbl mostly follows the gcode standard specifyed by Linuxcnc, so have a look at Linuxcnc’s reference documentation for g2 and g3 for more information.
    Oct 2019
    thanks that helped... looks like needed to switch planes to XZ first and then attempt the move with I and J.
    G18
    G2 X0 Z0 I1 J-1 F50
    Mar 2003
    Shelby Township
    Yes, you need to change planes. Not sure if GRBL supports G18-G19 though?
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
    Aug 2009
    G17, G18, & G19 are supported.
