Need Help! PRT-E1500W VFD CNC60/90 locked out - cant change VFD settings, flashing 50.00
Results 1 to 2 of 2
Thread: PRT-E1500W VFD CNC60/90 locked out - cant change VFD settings, flashing 50.00
    Member nheydari's Avatar
    Oct 2019
    Smile PRT-E1500W VFD CNC60/90 locked out - cant change VFD settings, flashing 50.00
    Hello!
    I was following a guide for setting up the spindle, and after I set d176 to 1, it seems that it's locked me out or something.
    I can't change anything apart from d176 and d001, and even when I do change those and press the function button, it goes back to flashing 50.00.
    I was able to change the numbers before I set d176 to 1.
    I'm wondering if this has anything to do with the voltage?
    The machine is in the UK, so 220v, I have a feeling that factory defaults changed the voltage to 110v. Now even in manual mode, when I press run, the spindles starts to accelerate and within about 3 seconds it stops and the display outputs E O or E R (can't remember as I'm not with the machine right now). Anyway that's my guess but I really have no idea.
    Would love some help with this, very new to it!
    Thanks a lot.
    Oct 2019
    Default Re: PRT-E1500W VFD CNC60/90 locked out - cant change VFD settings, flashing 50.00
