Condition on pickup was okay, the seller hadn't used it in years so a lot of old grease and dust but no obvious structural issues. Size comparison here next to my old 3040.
Hello to all! Just took ownership of this 6040 1.5kW machine second hand. Brand new to the forums but looking forward to making a few small improvements and sharing some pictures here along the way. From my searches so far, this looks like a great community!
First order of business was a full teardown and rebuild of the frame. Took my time cleaning out old grease and dust and then slowly reassembled with all new oil and grease. Used the granite slab to true things up wherever possible.
Finished the rebuild of the structure. All motors are operating smoothly now. Also found that the old spindle had a bit of corrosion at the water cooling ports. Ran a mixture of LCR and water for an hour and cleaned it out.
Worked over the weekend a bit on a base for the enclosure. The bottom section houses a silencer and cyclone (dust deputy) for my shop vac. The new top section will act as a home for the new Control box, VFD, water cooling, and a drawer for misc tooling.
Cabinet top painted, covered with toolbox liner, and mounted to shop vac base.
Great work mate!!
Started work on the enclosure last night. Using and old VCR top/bottom combined with some scrap aluminum plate and this black 3U aluminum faceplate from amazon.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Great build...Very nice work.
One thought....You have very restricted air flow around your control box, locating it in that spot.
You may have heat problems, especially in the warmer months.
Sent from my SM-G920I using Tapatalk
Very good point. The back of the wood cabinet is open and there is clearance at the top of the case. I was planning a fan at the rear of the box in push configuration to blow cold air into the box and then exhaust top and sides.
How warm do your drivers get? I'll be running DM556T drivers at about 3A, well under their 5.6 max. My hope was this would put them well into their ambient temp operating range.
Worst case I mount them to a cooling plate and put them on the closed loop. ....water cooled stepper drivers sounds fancy.
More work on the control box. My plan is to create two separate EMI zones separated by an aluminum plate. Also, using aluminum rivnuts as risers to allow some airflow under the components. Drives mounted to an aluminum plate for additional heatsinking.
Well done. Looks nice!
