Need Help! Chinese CNC Retrofit G540
Results 1 to 5 of 5
Thread: Chinese CNC Retrofit G540
    Sep 2017
    Default Chinese CNC Retrofit G540
    I got a Chinese CNC that I retrofitted with a G540. However, I cannot get the stepper motors to operate smoothly. I would appreciate any help offered. My guess is that it's a Mach3 software issue because I tried a 4th axis stepper motor from another machine and it does the exact same thing as these three stepper motors. Here's a link to a youtube video for it.
    Thanks for the help.
    Jan 2010
    united states
    Default Re: Chinese CNC Retrofit G540
    The first thought that comes to mind is that a 24 volt power supply seems very small. What power supply did it come with originally?
    Sep 2017
    That’s the size of the original power supply. It’s jumpy with only moving one stepper motor at a time.
    Sep 2017
    could this possibly be a reversed polarity issue on the stepper motors?
    Member Sterob's Avatar
    Jan 2007
    Got a Multimeter? Measure the DC volts of the power supply when you try to move the stepper. it *might* give you a clue.
