6040 error code and spindle not working. Help! - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 24 of 24
Thread: 6040 error code and spindle not working. Help!
  1. #13
    Member Gom's Avatar
    Mar 2018
    Default Re: 6040 error code and spindle not working. Help!
    Well, I did what the seller instructed me to do and...nothing. It did sweet FA.
    So I emailed and let them know, and also mentioned I only tested from MI1 to MI4 (I mentioned this because in their instructions they mentioned MI5).
    Their reply was something like, "There are tens of MI's. You need to check them all to find the fault".
    I replied with a picture of the board showing MI1 to MI4. No tens of MI's to be found.
    They then said "oh, sorry, my mistake", and then asked me to send a video of the process I did (I guess to make sure I followed their instructions correctly). I obviously had no video and wasnt going to do it all again just to video it so I explained at length and in no uncertain terms what I did...exactly.
    No reply.
    Sigh.
    So my hopes of getting a solutuon from the seller are approaching zero after this. They seem to have no idea.
    So again thinking I could get a cheap VFD from ebay and just go from there...
  2. #14
    ericks
    Guest
    Why dont you post some detailed pics of your setup....maybe i can identify your drive and assist you??
  3. #15
    Member Gom's Avatar
    Mar 2018
    6040 error code and spindle not working. Help!-2019-06-19-20-32-58-jpg
    - - - Updated - - -
    And thanks for taking the time mate
    Attached Thumbnails Attached Thumbnails 6040 error code and spindle not working. Help!-2019-06-19-20-32-58-jpg
  4. #16
    ericks
    Guest
    Thanks....i need to see all the terminals to make out the writing. Also need to see any switches on the pc board
  5. #17
    Member Gom's Avatar
    Mar 2018
    Here are some more pics of everything in the controller box.
    6040 error code and spindle not working. Help!-20190620_155248-jpg6040 error code and spindle not working. Help!-20190620_155432-jpg6040 error code and spindle not working. Help!-20190620_155523-jpg6040 error code and spindle not working. Help!-2019-06-20-16-11-36-jpg6040 error code and spindle not working. Help!-2019-06-20-16-12-26-jpg6040 error code and spindle not working. Help!-2019-06-20-16-13-06-jpg6040 error code and spindle not working. Help!-2019-06-20-16-13-52-jpg
    Attached Thumbnails Attached Thumbnails 6040 error code and spindle not working. Help!-20190620_155248-jpg   6040 error code and spindle not working. Help!-20190620_155432-jpg   6040 error code and spindle not working. Help!-20190620_155523-jpg   6040 error code and spindle not working. Help!-2019-06-20-16-11-36-jpg
    6040 error code and spindle not working. Help!-2019-06-20-16-12-26-jpg   6040 error code and spindle not working. Help!-2019-06-20-16-13-06-jpg   6040 error code and spindle not working. Help!-2019-06-20-16-13-52-jpg
  6. #18
    ericks
    Guest
    Thanks for the pic's. Without the drive parameters it's will be hard to help you with adjusting the parameters correctly. I am unable to find the relevant manual
  7. #19
    Member Gom's Avatar
    Mar 2018
    Quote Originally Posted by ericks View Post
    How would I adjust them? These are the dxxx?
    Just to be clear...the VFD is totally unresponsive. E CH stuck on display. None of the buttons do anything so there needs to be another way to change them...
  8. #20
    ericks
    Guest
    Quote Originally Posted by Gom View Post
    If i had a manual then i could check....but without a manual its impossible.
  9. #21
    Member Gom's Avatar
    Mar 2018
    Well I ended up just getting a new VFD and will run the spindle manually.
    But I don't know how to program it for my spindle. Any help?
    Spindle info:Power: 1.5KW
    Voltage: 220V
    Frequency: 0-400HZ
    Speed: 0-24000RPM
    See pics for the VFD manual.
    Hopefully someone can help me. I changed a couple of parameters that I thought might be the way to go and tried it. The spindle starts up and spins but quickly (1 second) gives me an error 1 (short circuit/current overload/power module protection). So obviously didn't do it right.
    6040 error code and spindle not working. Help!-20190627_154730-jpg6040 error code and spindle not working. Help!-2019-06-27-16-14-15-jpg6040 error code and spindle not working. Help!-2019-06-27-16-08-39-jpg6040 error code and spindle not working. Help!-2019-06-27-16-11-10-jpg6040 error code and spindle not working. Help!-2019-06-27-16-12-33-jpg6040 error code and spindle not working. Help!-2019-06-27-16-13-06-jpg6040 error code and spindle not working. Help!-2019-06-27-16-13-59-jpg
    Attached Thumbnails Attached Thumbnails 6040 error code and spindle not working. Help!-20190627_154730-jpg   6040 error code and spindle not working. Help!-20190627_154747-jpg   6040 error code and spindle not working. Help!-2019-06-27-16-08-39-jpg   6040 error code and spindle not working. Help!-2019-06-27-16-11-10-jpg
    6040 error code and spindle not working. Help!-2019-06-27-16-12-33-jpg   6040 error code and spindle not working. Help!-2019-06-27-16-13-06-jpg   6040 error code and spindle not working. Help!-2019-06-27-16-13-59-jpg   6040 error code and spindle not working. Help!-2019-06-27-16-14-15-jpg
  10. #22
    Jan 2005
    You are looking at them in this photo show them clearly, that is the complete open board VFD Drive these machines have Power in Power out to spindle it's all connected correct, the only thing missing is the Ground wiring which is normal for these machines, which need to be rewired with Ground wires
    Programing is usually what these machines have problems with
    Mactec54
  11. #23
    Jan 2005
    Voltage: 220V
    Frequency: 0-400HZ
    Speed: 0-24000RPM
    Is this an AT1 Drive need the Drive Name Spec's
    Mactec54
  12. #24
    Member Gom's Avatar
    Mar 2018
    Aiight. I got it working. Thanks to those who tried to help.
    I will upload my current parameters later in case anyone else finds this thread in the future.
