Need Help! CNC Controller not powering up
Results 1 to 2 of 2
Thread: CNC Controller not powering up
    Member Rkjt's Avatar
    May 2019
    Default CNC Controller not powering up
    I think I might have burnt out the controller. I had the z axis too low and the bit resting hard on the wood when I turned on the spindle, I thought it was just off the wood but I didn’t notice it, now there is no power in the controller at all. I checked the fuse, and the only fuse I could find was on the power board, but it was ok. Does anyone where the problem could lie?
    Attached Thumbnails Attached Thumbnails CNC Controller not powering up-thumbnail_img_1808-jpg
    Member john-100's Avatar
    Mar 2007
    uk
    Default Re: CNC Controller not powering up
    have you checked the fuse in the IEC mains inlet ?
    CNC Controller not powering up-uk_bulgin_-flange-fused-inlet-jpg
    if the fuse in the inlet is OK,
    the mains ON /OFF switch should be Illuminated when switched on
    John
