CNC 3040 Switching from Broken Y-axis driver to A-axis driver in software.
I recently purchased a CNC 3040 from ebay. I have successful created several designs, however I noticed a major amount of error in my Y distance. The problem started to get worse and is currently to the point where it is near 15mm of error every time it moves. I did the standard trouble shooting to figure out that every time any sort of motor was connected to the Y axis driver then it would have this error. The motor, connector, or mechanical axis work perfectly when another driver(I.E x axis) is used. More recently, I tried to correctly ground everything together and the problem still occurs.
Nevertheless, I ordered from aliexpress the JP-382A board. However, it will take almost 10 days until I get the board and can run my CNC again. I wanted to see if there was any quick way to switch the A axis with the Y axis in the software? If I can use my A axis as a replacement until my new board comes in, it would save me a lot of time.
I was able to switch the axis(Axis 2 is now A not Y anymore) in CNC USB controller software, but when I plug my motor into the appropriate port, the motor does not move. I wasn't sure if there was a special to set up the board(JP-1635A) as the motors get power when they connected, but will not move. I am assuming it is sometime fairly simple, such as another program? The red light on the JP-1635A is on and that may be a hint of an internal error?
Re: CNC 3040 Switching from Broken Y-axis driver to A-axis driver in software.
I am currently using CNC USBController. Do you know of any way to do the switch in CNC USB Controller? If not, do you think moving to Mach3 would be preferred in the long run?
which CNC USBController are you using ?
some like warp9 tech designs smoothstepper
or usb motion controls UC100
works with mach 3 and mach4
and you would follow the change in config as in my first reply
other USB motion controllers use the manufactures software not Mach3/4 so you will need the manual for that
one from https://planet-cnc.com comes to mind but I can't remember all the details
John,
I am using the CNC USB Controller from PlanetCNC(https://planet-cnc.com/software/). It works well other than the fact that I can't change my pin for my y-axis. I will try Mach3 with your recommendation and changing the config files.
