PRT-E1500W 110V VFD SETTINGS for USB CNCEST-6040T
Results 1 to 11 of 11
Thread: PRT-E1500W 110V VFD SETTINGS for USB CNCEST-6040T
    Member mjmurphy99's Avatar
    Apr 2019
    Default PRT-E1500W 110V VFD SETTINGS for USB CNCEST-6040T
    Help on VFD Settings,
    I Have the PRT-E1500W 110V VFD USB CNCEST-6040T
    I have contacted the supplier and get no response if my setting are correct for this CNC.
    Can some one with the same Machine or knowledge of the setting can tell me if this is correct!
    I made some changes to the 199 d-codes and now it runs with pc and manual, were before the spindle would not, Manual or Mach3 PC.
    I got this list from the net but the post was for a 220V spindle and mine is 110V.
    I also could not change d072 => 1000 it is at 0000 now! is this a problem?
    I also noticed that d021 => 50 and other posts say 400 is this a problem?
    Can some one check there d-codes and compare. I really don’t want to take a chance that the codes are wrong before I start using this CNC.
    Thanks for any input.
    Attached Files Attached Files
    Activation process kgoods's Avatar
    Jan 2019
    Default Re: PRT-E1500W 110V VFD SETTINGS for USB CNCEST-6040T
    Take a look at this thread... the second post has a link to the most comprehensive manual I've seen on these VFD's.
    https://www.cnczone.com/forums/chine...s-use-ith.html
    Just click on the download button (for english or french) and get ready to be amazed! Be sure to thank etiennebertrand for taking the time to put this together!
    It appears that d072 has to do with the PID functions which you most likely don't have (it's a feed back sensor from the spindle) If d070 = 0 then don't worry about it as PID is not implimented.
    d021 appears to be the max freq for "multifunction mode"... not even sure what that is but it shouldn't have any effect unless you're using that mode.
    I have the same machine 110v 1500W (although it's a 6090 4 axis) but have not got it set up yet, need to build a bench. But I'm sure with the help of the manual I won't have any problems.
    Hope this helps!
    Also if you haven't seen this thread be sure to go through it as well, lots of good info.
    https://www.cnczone.com/forums/chine...698-cnc-4.html
    Apr 2019
    Quote Originally Posted by mjmurphy99 View Post
    This is the answer I got from my supplier warehouse in CA took 4 days to receive the 6040T CNCEST:
    SNIP ---------------------------------------------------------------
    Goodday
    thanks
    and I have ask factory and it will not effect the usage
    and please do not worry
    you just need to know how to manaul control or adjust and it is ok
    best regards
    I asked if the d-codes were ok they made the spindle work and Mach3 PC switch works know!
    The reply I was wanting was all correct d-codes 0 - 199 I will Run with these codes Attached for know.
    Apr 2019
    Ready to carve now!
    I'm really quite impressed with this CNCEST-6040T
    The table bed serves great! to attach my topper - (2) 5/8 particle board!!
    Attached Thumbnails Attached Thumbnails PRT-E1500W 110V VFD SETTINGS for USB CNCEST-6040T-20190509_221437-jpg
    Apr 2019
    You must use a washer on the bolt to lock the head in the track.
    Attached Thumbnails Attached Thumbnails PRT-E1500W 110V VFD SETTINGS for USB CNCEST-6040T-20190509_191513-jpg
    Apr 2019
    Another bit of important info for mach3 install the instructions weren't clear at first but the English Crack! is to copy the correct files from "engraver" folder it creates to mach3 folder. Page 6 install manual Attached.
    https://www.ebay.com/itm/4AXIS-USB-C...72.m2749.l2649
    I'm overall very happy with this purchase. I think it is a great bargain for the cost!
    I wonder if the cost are going to increase now with Chinese Tariffs!!
  7. #7
    Apr 2019
    Dust Shoe and VAC installed! Works Great!
    Attached Thumbnails Attached Thumbnails PRT-E1500W 110V VFD SETTINGS for USB CNCEST-6040T-20190531_211429-jpg   PRT-E1500W 110V VFD SETTINGS for USB CNCEST-6040T-20190531_211719-jpg
  8. #8
    Apr 2019
    First project with Diamond Drag Bit I'm amazed at this CNCEST accuracy The Dragons eye pupal is 1mm in diameter.
    I used Vectric Vcarve Desktop very nice program easy to learn.
    The drag bit was found on ebay very good bit! reasonable price.
    https://www.ebay.com/itm/6mm-MSS-DRA...72.m2749.l2649
    Attached Thumbnails Attached Thumbnails PRT-E1500W 110V VFD SETTINGS for USB CNCEST-6040T-p1120994a-jpg   PRT-E1500W 110V VFD SETTINGS for USB CNCEST-6040T-p1120993a-jpg
  9. #9
    Member Sterob's Avatar
    Jan 2007
    Very nicely done..
  10. #10
    Apr 2019
    Cool Re: PRT-E1500W 110V VFD SETTINGS for USB CNCEST-6040T
    My First Clock Project
    Toucan Wood Gear Clock,
    Clayton Boyer Has done a very nice and well thought out plan/Drawing on this Clock Art!
    Thanks Clayton!
    Attached Thumbnails Attached Thumbnails PRT-E1500W 110V VFD SETTINGS for USB CNCEST-6040T-p1130020-jpg   PRT-E1500W 110V VFD SETTINGS for USB CNCEST-6040T-p1130017-jpg   PRT-E1500W 110V VFD SETTINGS for USB CNCEST-6040T-p1130022-jpg
  11. #11
    Apr 2019
    My first 4th Axis Project was to carve the tread on the UniMog
    Attached Thumbnails Attached Thumbnails PRT-E1500W 110V VFD SETTINGS for USB CNCEST-6040T-20200626_193522-jpg   PRT-E1500W 110V VFD SETTINGS for USB CNCEST-6040T-20200626_183629-jpg   PRT-E1500W 110V VFD SETTINGS for USB CNCEST-6040T-20200626_193551-jpg
