Originally Posted by
lesterb
We have a 6050 CNC router and are having problems with it stopping intermitently. Part way through a job it will stop moving but the cutter is still spinning and Mach3 is still processing lines of gcode, hence, the system loses it's reference to the zero point. We can stop Mach3, move the cutter back to the original zero, reset the X & Y axis then restart the job from a few lines before it stopped. Sometimes this will happen a couple of times during a job.It is obviously the hardware because Mach3 is not aware that it has stopped and keeps processing lines of gcode.
We have the work around but what is the solution? What could be wrong with the hardware?
