NCStudio - Auto Tool Sensing 3 axes - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 24 of 24
Thread: NCStudio - Auto Tool Sensing 3 axes
  1. #13
    Jan 2007
    Default Re: NCStudio - Auto Tool Sensing 3 axes
    well
    what you mean try to study a bit?
    if you don't read the manual, then you wont figure it out..
    when did you buy this machine?
    what machine is it?
    have you ever read the manual?
    weihong has the V8 and V10 uploaded on their site
    you better off follow the manual, that says what version can be installed..
    I know what I were do.. but I can not tell you install it..
    the V10 manual says V10 works with your card, but I didn't say you have to install it
    the V8 also has the auto centering function
    see 45 page
    http://weihong.com.cn/en/uploads/sof...60Q6111540.pdf
    if you don't do your home work, then no one can help..
  2. #14
    Jan 2007
    what I am sure, if I ever add 4th axis or ATC I going to use either way weihong or syntec control..
  3. #15
    Jul 2017
    Portugal
    I know you did not tell me to install the V10. I asked if I could?
    I bought my machine in china. Chinese manuals are very limited.
    I'm learning by the way. And with the help of people like you who help me in the forums.
    This is my machine:
    https://www.cncrouter-shop.com/pro/2...r-door-making/
    The card is the same, but the Lambada is weaker.
    Mine is the Lambada 3L.
  4. #16
    Jul 2017
    Portugal
    NCStudio - Auto Tool Sensing 3 axes-2018-03-29-11-49-44-jpg
    Attached Thumbnails Attached Thumbnails NCStudio - Auto Tool Sensing 3 axes-12-jpg   NCStudio - Auto Tool Sensing 3 axes-2018-03-29-11-49-44-jpg
  5. #17
    Jan 2007
    you got a great machine
    I know people bought from blue elephant and they like it
    the program associated with the card you have in the computer
    trough on pci bus is very reliable
    this is the version 8 docu..
    I firmly believe the version ten should be ok, but I can not tell you go ahead and install..
    I think very minimal the real difference between V8 and V10
    the links I posted, please download the PDFs and really jump on and start to read them
    very important don't try to set what they were set...
    for the original question theres the option to install an auto zero..
    but I think first try to use stops to align parts..
    its safer and I think faster
    either way use the popup pins if they installed or screw down on the spoilboard scrap pieces and mill to a known measurement..
    by the way
    what kind of job you plan to do with the machine?
    my friend has a shop , and he makes doors windows to the 63 or the 68 mm standard..
    but he purchased an Italian door-window machine..
  6. #18
    Jan 2007
    do you have hand wheel for the machine?
    I just asking because I don't see plugged in into control
  7. #19
    Jul 2017
    Portugal
    I do not have.
    when it was negotiated it was to have. but then there was a mistake from them and it did not work.
    made a discount.
    I'm sorry I do not have it.
    I want to make hurricanes for hinges on the doors and other things.
    Enviado do meu iPhone usando o Tapatalk
  8. #20
    Jan 2007
    first try to get a pendant
    this is a very large sized machine to jogging and setting up from several meters distance
    what is good thing, the Z axis sufficiently large if you need a horizontal spindle.. for working on doorslab edges like milling in the lock..
    and again, download the PDFs and realy get learning it..
    mechanically machine is good, and I think the control itself not less or worse from other controls..
    so you need to get working the machine and producing some income with
    im started with turbocnc, then mach3 then ncstudio
    if I were have to back, I would choose turbocnc over mach3, altought that was lacking the continuous velocity..
  9. #21
    Jul 2017
    Portugal
  10. #22
    Jul 2017
    Portugal
    Yes, I'm going to read it very carefully.
    But it's complicated for me. Because my English is weak.
    And when the pfd is translated the translation is not good.
    I already know how to work with the machine.
    I use Aspire, I make the drawings I create the gcode and it works well.
    But I bought mine for 80% to do this job.
    And I do not know yet how to create Gcode for horizontal spindle.
    And write gcode manually I do not know.
    As you have experience, you do not know to give me a solution, that is easy and practical for me?
  11. #23
    Member Eitanbarazani's Avatar
    Jun 2019
    This link doesn't work. Do you have a new link?
    Thx
    Eitan
  12. #24
    Jul 2017
    Portugal
