Have a look in your C:/ Mach3/plugins folder. Your should have a driver file for YOUR particular control board in there.
It will have the file extension ".dll" You have to manually copy it across. Did you do that?
That will allow Mach 3 to interface with your board.
If the Supplied didn't supply it, you will have to identify your board and find the correct file.
