Hello. I am having to switch my CAM from Rhino 1.0 to Fusion 360 after 5 years using rhino with my JCUT Router (with a handheld controller). I originally used a Fanuc type post processor from the rhino menu (can't recall which Fanuc it was) and it posted very simple g code, which worked (see comparisons below). Now the Fusion 360 simulates just fine from a Fanuc post but when I put the file (converted to .tap) into my machine it doesn't move in the Z direction after its first g00 absolute positioning. Seemingly the g01 Z movement is being blocked or ??? Any ideas?
Sample of code (first 48 lines) I have been using successfully (sample of new code that doesn't move Z below)
T1
N1M03S4583
N2G00X330.632Y251.329Z161.998
N3G01Z151.209F762.
N4X344.815Y234.179F2540.
N5X348.03Y229.06
N6X350.745Y223.659
N7X352.936Y218.025
N8X318.321Y251.334
N9X336.439Y229.699
N10X336.895Y229.083
N11X337.72Y227.812
N12X338.111Y227.121
N13X352.948Y196.484
N14G00Z161.369
N15X305.805Y251.339
N16G01Z151.209F762.
N17X306.311Y250.84F2540.
N18X328.091Y225.165
N19X328.55Y224.553
N20X329.383Y223.29
N21X329.778Y222.6
N22X352.959Y175.516
N23G00Z161.369
N24X291.175Y251.345
N25G01Z151.209F762.
N26X297.876Y245.894F2540.
N27X298.681Y245.111
N28X319.741Y220.629
N29X320.213Y220.008
N30X321.076Y218.711
N31X321.467Y218.036
N32X344.321Y172.396
N33X344.816Y171.04
N34X352.143Y140.512
N35X352.314Y139.24
N36X352.991Y118.421
N37G00Z161.369
N38X353.051Y8.137
N39G01Z151.209F762.
N40X338.48Y-14.331F2540.
N41X337.861Y-15.136
N42X330.919Y-22.806
N43G00Z161.369
N44X353.04Y28.522
N45G01Z151.209F762.
N46X350.208Y21.475F2540.
N47X349.665Y20.421
N48X331.742Y-7.573
In the new coding Z does not seem to respond to G01
O1001
(T1 D=31.75 CR=0. - ZMIN=-109.531 - FLAT END MILL)
N10 G90 G94 G17 G49 G40 G80
N15 G21
N20 G28 G91 Z0.
N25 G90
(POCKET2)
N30 T1 M06
N35 S5000 M03
N40 G54
N45 G00 X130.859 Y128.661
N50 G43 Z35. H01
N55 G00 Z12.623
N60 G01 X130.841 Y128.667 Z12.275 F333.
N65 X130.786 Y128.682 Z11.932
N70 X130.695 Y128.708 Z11.597
N75 X130.57 Y128.742 Z11.274
N80 X130.41 Y128.784 Z10.968
N85 X130.218 Y128.831 Z10.681
N90 X129.996 Y128.883 Z10.418
N95 G03 X129.747 Y128.937 Z10.181 I-3.319 J-14.712
N100 X129.473 Y128.991 Z9.973 I-3.069 J-14.766
N105 X129.177 Y129.044 Z9.798 I-2.795 J-14.82
N110 X128.863 Y129.094 Z9.656 I-2.499 J-14.873
N115 X128.534 Y129.138 Z9.55 I-2.185 J-14.922
N120 X128.195 Y129.176 Z9.481 I-1.856 J-14.967
N125 X127.85 Y129.207 Z9.45 I-1.517 J-15.005
N130 X125.506 Y99.136 Z7.795 I-1.172 J-15.036
N135 X127.85 Y129.207 Z6.141 I1.172 J15.036
N140 X125.506 Y99.136 Z4.486 I-1.172 J-15.036
N145 X127.85 Y129.207 Z2.832 I1.172 J15.036
N150 X125.506 Y99.136 Z1.177 I-1.172 J-15.036
N155 X127.85 Y129.207 Z-0.477 I1.172 J15.036
N160 X125.506 Y99.136 Z-2.132 I-1.172 J-15.036
