Need Help! 3040 CNC
Results 1 to 2 of 2
Thread: 3040 CNC
    Aug 2011
    Default 3040 CNC
    I have been using my Chinese 3040 CNC machine with a parallel port for about 6 years and has recently developed a problem with the Z axis. It begins to engrave at the set depth but will suddenly get deeper as the job continues. I have no electronics skills apart from cleaning contacts Mechanically the machine seems fine so I am guessing it is an electronic problem. I am running Mach 3 software with Lazy Cam.
    Jun 2017
    Default Re: 3040 CNC
    Quote Originally Posted by johntodd View Post
    My 6040 had an axis "moving" out of position during machining recently and it ended up being the bob.....after seven years use.
3040 CNC
3040 CNC
