What are your GRBL settings, can you post them ($$ command from terminal).
Hi all! I bought a cheap Woodpecker 3.0 GRBL (unfortunately without any manual) and installed it on a Win 7 PC. I don't have any experience with CNC technology, so I thought learning by doing. With the GRBL software I could operate the machine manually. When I clicked on the Home function, the machine went to a position in the middle of the work field and since then there has been no movement at all. Stepper and spindle motors don't react at all. I have already reinstalled the software twice, unfortunately no results at all.
Who can help me??????????
- Problem- STATUS PROBLEM with 3018, woodpecker, Grbl controller,
- NOOB NEEDS HELP HAVE A CNC 3018 WITH A "WOODPECKER CNC GRBL 0.9 BOARD) NEED TO UP RPM
- Need Help!- Chinese CNC 160x100 mm with Woodpecker Controller
- Need Help!- any one that knows Audrino and grbl shield with grbl pannel?....
- Need Help!- Woodpecker CNC Not Registering With Computer
Make no mistake between my personality and my attitude.
My personality is who I am. My attitude depends on who you are.
I tried several commands ($$ and $X to because I think the machine is in an alarm status). Unfortunately no reaction. I'm not sure where to enter the commands. I now only have the GRBL program where I can enter and send something in the bottom right corner of Console. Where should I see the answer from the machine?
GRBL is the firmware which resides in Arduino board.
What is your software tha communicates with GRBL?
bCNC or UGS (universal GCode sender) or ...
