Hello,
i have a problem with exported gcode from Fusion 360:
if i select Mach3mill as posprocessor the Z axis doesen't rise up before it starts to mill, so the endmill bit will crash in the object.
I use the provided USB Software and i don't know wich postprocessor i have to select.
Can anyone help me?
Thank You.
I found a solution:
i generate the gcode selecting the Mach3mill postprocessor, then i home all the axes, i rise the Z axis 1-2cm above the piece to mill and then i start milling.
Is there any modification to the postprocessor that i can make to rise the Z axis automatically? The thinyG postprocessor does that, but i use Mach3 or the provided Software.
