6040 CNC spindle only spinning in manual mode
Results 1 to 7 of 7
Thread: 6040 CNC spindle only spinning in manual mode
    *Registered User* vosser's Avatar
    Aug 2018
    Default 6040 CNC spindle only spinning in manual mode
    Hey!
    First of I'm very new to all of this and have just put together a 6040 using the included (very limited) instructions on a windows 7 machine. And as I'm trying to demonstrate in the video below the x, y, and z move just fine, but the spindle will not start when trying to through g code. I can how ever switch the cnc control box over to manual and get the spindle to run.
    Any tips would be very welcome!
    Mar 2016
    Default Re: 6040 CNC spindle only spinning in manual mode
    Quote Originally Posted by vosser View Post
    Hey!
    Look in this thread for the manual, it's been a while since I toggled the settings but it is maybe d032 you have to change 0 to 1 for external control
    Sent from my Nexus 6 using Tapatalk
    Aug 2018
    Quote Originally Posted by carl1961 View Post
    Which thread did you mean?
    Mar 2016
    I meant the https://www.cnczone.com/forums/chine...698-cnc-4.html, that has a lot of help for your VFD
    since you seem to have your VFD running manual, what you need is on your VFD Set D031 to 1 so mach3 can control the spindle that switch does not automatically switch you to manual or remote PC, it just tell your VFD your running manual or the PC, if you want to go back to manual control you will have to manually set D031 back to 0
    Aug 2018
    Ah I see. I did just now actually get it to work. I'm not sure if this is the proper way to do it or if this is bad in some way.
    Would love a comment on why this is not as in the manual when everything else is.
    Also. any ideas on how I get the actual RPM in Mach3?
    Member Sterob's Avatar
    Jan 2007
    Well done...your making progress!
  7. #7
    Mar 2016
    You can get it close but your RPM will never be exact. in mach3 I will post my setting when I get home from work ok.
    OK I made a PDF with Google DOC's of the screen shots Hope it helps. oops I miss spelled CNCEST! Spindle setting for the speed as close as I could get it is on page 5 also same page the MPG #1 you can uncheck,I have a wireless MPG that needs that turned on to work. I have used my CNC numerous times with these settings, the motor calibrations or right on it. anyone with better settings I would be glad to try.
    Attached Files Attached Files
