Hey guys. Just got done hooking up my new UC300eth-UB1 and I have nice smooth movement on all 3 axis. I'm just having trouble hooking up the spindle control. I can't get the spindle to turn on with the toggle on the MACH screen. As you can see in the picture i have my inputs from the invertor hooked up to DCM- AL and forward to AH. On the POT side I have ACN-Ground, AVI- AV1 and 10v to ACC. Any help would be greatly appreciated.
Is this a Huanyang?
You don't appear to have the relay connected, which is what starts and stops the spindle.
FWD to CM2
DCM to NO2
In Mach3, the M3 output should be Port 1 pin 14.
UCCNC 2017 Screenset
ty
I'm on vacation, so there might be a slight delay of you purchase. But it shouldn't be too long, as we're probably just hanging around the house all day (on the lake )
Hey Gerry. Yes it is a Huanyang. I moved the forward and the DMC to where you said. Still no spindle. I currently have the ACM hook to ground. The AV1 hooked to AIN1 and the 10v hooked to VCC. in the upper right side of the board. Is that correct?
Not the VFD.
This is how it should be wired.
Huanyang > UB1
+10 > AH1
ACM > AL1
VI > AO1
And make sure your PD001 and PD002 settings are correct.
If the VFD has a pot, there's a jumper that may need to be changed as well.
Ty Gerry. I was way off. Think you have me on the right track. Just have to figure the jumper thing out.
I have +12 going to AH1
FV is the input for my VFD which is connected to A01
FC is the common ground for my VFD connected to AL1
The connections at k2 are good because the spindle with start/stop when it's supposed to but I have no speed control.
AO1 gives me the same voltage out as is put into AH1.
I had bad connections through my wiring harness. Problem solved with some new wires.
