Originally Posted by
SyntecEngineer
Hi Wwagner,
So it does seem like all the normally closed switches are getting triggered, which means the communication from the input board to the controller is most likely damaged. If you can double check the cable and wiring first, we can then check to see if replacing the input board will fix the problem. I will send you an email so we can get you the parts that will fix the problem.
Sorry for the delay, there was a personal shift in who was monitoring this account for support.
