Did you get machine to work?
I have the same problem
I am new to CNC so please bear with me.
I have recently bought a used Soda SD3025(M variant with the 1500W Spindle) and can't get it to work. I believe it is a 2006/2007 model.
It was not supplied with a communication cable and hence I have no idea how it should work. It was however supplied with manuals, but they are not helpful. I have a CD with 'ARTSPOOL' which is what I am using to try to communicate.
The machine powers on, and I can manually move the X, Y and Z axis with the on-board controller/display panel and it all works fine. I just cannot send any programs to the machine.
It has a USB (Type A) port on the side, near to the display panel and a female serial port on the back. I have tried multiple ways to try and send files to it, but nothing happens. These include:
USB pen drive
USB to USB cable
USB to Serial cable
Parallel to Serial cable
I have also tried multiple computers with operating systems going back to Windows 2000. I have also tried multiple file types including G-code, HPGL, NC and DXF.
I have seen other threads on this forum about similar machines, but they don't really explain a solution.
Does anyone have one of these? Has anyone used one? Is there a procedure I should be following?
Any suggestions would be greatly appreciated!
