This is for all the owner of a Chinese 6040 CNC engraver!!
Results 1 to 3 of 3
Thread: This is for all the owner of a Chinese 6040 CNC engraver!!
    Jul 2017
    Default This is for all the owner of a Chinese 6040 CNC engraver!!
    I just got a 6040 off ebay in 220v with a 2200w spindle and I need a photo of the wires that are hooked the 220v power supply. I had two wires get loose and they are the same length,,one yellow and green and one black and I need to know where they go. Thanks,
    Apr 2018
    Default Re: This is for all the owner of a Chinese 6040 CNC engraver!!
    yellow green is international standard earth or ground. this will connect to the chassis/frame of your machine. the other is AC LINE or MAINS. goes to power supply beside a white wire possibly. look for VAC IN or something like that. hope that helps.
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by rokk View Post
    Why do you have multiple posts asking the same question
    Mactec54
