No one ?
Hi all,
I have receive my Chinese CNC some days ago.
I'd like to add end limit switch on each axis.
No problem for the switch placement and fixing, but I need you help and ideas on where to wire it on the main board of the controller.
I guess it's on the Phoenix connector (see attached photos)
I have slots available named :
REV / MI1 / MI2 / MI3 / MI4 / Mo1 / +12V.
Did someone can guide me for the switch wiring ?
And if possible, on Mach3 settings (or a right link).
I'll will use a Z prob too, I have buy a cheap molule on Ebay, if any one have information on how to wire it and set it in Mach3, thank you.
Thank you in advance.
Regards.
- Anyone upgrade the deck of 3020 to a vacuum setup? Possible? Or increase Z axis?
- Installing Z-axis End-Stop Limit Switches On My Mini-CNC 3020 Engraving Router Part 1
- Installing Y-axis Limit Switches On My Mini-CNC 3020 Engraving Router Part 2
- Need Help!- can anyone recommend a spindle upgrade for CNC 3020?
- Need Help!- CNC 3020 Spindle upgrade??
No one ?
Solved
Ok i see the page, but the Mi1 Mi2 Mi3 Mi4 Mo1 +12v, is not listed in these prints... i would like a Z Zero plate, or to make one for my
Cnc machine.
