With the power OFF gently wind all the steppers through all the travel.
Are they free and smooth? If not you may need to lubricate your rails and ball screws.
I use light machine oil.....like sew machine oil..
Let us know what you find.
Steve
Hello everyone.
I got this small cnc machine from cncrouter.cn back in 2016.
It worked fine for about 1 year and then if started missing the origin point.
When making repeated work in series i was not moving it to home, but to origin and it was working good.
Then all the sudden every next repeat it would start slowly moving the Y origin point toward out.
After few experiments it turns out that moving everything to HOME before each next job, solved the problem.
But now it started doing it again (in the opposite direction). Basically if i have to rebate 14mm and do it in 4 passes, every next pass will shift about 1mm in the Y axis.
Now the Chinese are indeed very helpful but their English is very poor.
The suggest to wipe out the machine software and make a new install. They say put the "upgrade file" from the CD you got with the machine on a USB, insert USD to the DSP A11 controler and "upgrade".
Now, there are several folders at the CD they sent, but whichever of them i put in the DSP USB slot and go to Auto Upgrade and chose USB file, it says folder is empty.
Here is what i have on the CD.
And here is how this pocket is cut so you can have a better idea what is happening.
It should have been at 90 degree, but instead it is stepped because the machine moves a bit on the y axix with every next pass.
Any help is greatly appreciated.
- Newbie- 6090 problem
- Problem- Laser cutting problem on a JD 6090
- Need Help!- 6090 CNC controller box problem
- Need Help!- Chinese CNC Router Problem XJ-6090 PLZ HELP :(
- Chinese 6090 router with DeskProto problem
Steve
The machine has oil pump that i pump before every use. So everything is oiled all the time. All clean too.
I'd still do that test if I were you.If you make assumptions, you may miss finding the problem.
Just my 2 cents worth....
