3040T y axis not only running in manual jog and g-code jog
So I have Chinese 3040T 4 axis cnc , with a planet CNC software, license I purchased from planet cnc, They were good enough to allow me buy one even though the serial number of the board was the cloned PCB) So everything manually jogged fine,( found y axis was backwards and set it to opposite to correct) and I decided to do a quick test with the "import text" function, typed a couple of letters and let it rip....noticed y axis motor only moved when it was jogging with the tool up...and not moving when it was cutting. Of course it did not cut the right shape....Anyone else have this issue ? Planet CNC has a tutorial showing how to replace the control driver board out with theirs, seriously thinking of doing this....figured I would put the question out see if anyone else experienced this issue....
