6040 4 axis Chinese CNC - Installing Limit Switches help - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 33 of 33
Thread: 6040 4 axis Chinese CNC - Installing Limit Switches help
  1. #21
    Jul 2017
    Default Re: 6040 4 axis Chinese CNC - Installing Limit Switches help
    My budget is 1250$
    any input on the ebay 6040 cnc with 1500watt spindle and 4 axis ?... https://www.ebay.com/itm/12294641142...&ul_noapp=true
  2. #22
    Mar 2016
    Hi Shelby, I just bought that same one. although well built Frame, it will not run out of the box. I finally got mine going after a months study and help from this thread. just search "PRT-E1500W " on this forum and you can read what everyone had to do to get things going. you can also go here and read about this machine The CNC Blog: Home if you not the type to work on it then don't buy that.
  3. #23
    Jul 2016
    France
    Hello,
    Long time post but anyone have the reply about MI1, MI2, MI3, MI4 and MO1.
    For X, Y, Z and Z prob ?
    Thank you.
  4. #24
    Jul 2016
    France
    Hello,
    Long time, but anyone have defin the X, Y, Z and Z prob connector ?
    Thank you.
  5. #25
    Member Sterob's Avatar
    Jan 2007
    Quote Originally Posted by 0JFK0 View Post
    Hello,
    Thank you.
    I think they are called GX16 connectors. Heaps on Ebay. '16' refers to the diameter...mm
  6. #26
    Jul 2016
    France
    Quote Originally Posted by Sterob View Post
    Hello,
    Thanks.
    On the cnc main board, wich are the inputs for the limit switch and Z probe?
    MI1, MI2, MI3...M01?
  7. #27
    Jan 2007
    Sorry, misunderstood what you were asking.
    Look at post #7 and 11 for limit switch info.
    Have not seen anything regarding Z probe.
  8. #28
    Post Re: 6040 4 axis Chinese CNC - Installing Limit Switches help
    hi all good morning
    I was wondering if some body could you help me to know how connect the limit switch in my CNC 6040 , my cnc use USB, and also if some body have experience for connect my cnc router and convert to Laser I want to attach laser 15 w for cut mdf from ebay
    thanks, Regards.
  9. #29
    adding picture
    Attached Thumbnails Attached Thumbnails 6040 4 axis Chinese CNC - Installing Limit Switches help-20190421_214642-jpg
  10. #30
    Activation process kgoods's Avatar
    Jan 2019
    Quote Originally Posted by mecanico3020 View Post
    hi all good morning
    thanks, Regards.
    Try this link https://buildyourcnc.com/Item/electr...ach3-USB-Board
    Go down to #14 and it shows a wiring diagram. Sorry, can't help you with the laser, I have no experience with them.
    Hope this helps.
  11. #31
    Member Butcher9_9's Avatar
    Apr 2019
    Quote Originally Posted by kgoods View Post
    Hope this helps.
    Just for clarification, based on that Diagram the USB controller is a bit more dumb with its limit switches. They are all wired to the same 2 Pins so other than smarts in Mach (hit limit which moving in X+ must be X+ switch) it has no way of knowing which switch is being activated. I guess that makes wiring it up easy as everything can have a common ground and signal.
  12. #32
    Jan 2019
    Quote Originally Posted by Butcher9_9 View Post
    Looks that way. I thought it was a little strange too but as you said, Mach knows which axis is moving so if it hits the limit that's all it needs to know. More concerning is that they are all normally open which means you would have no way of knowing if there was a wiring problem (broken wire) until it crashed into a machine limit. I'd much rather see these normally closed.
    BTW there is a full wiring diagram at the top of that page that is pretty clear on all the connections.
  13. #33
    Apr 2019
    Yeah I had seen that. Unfortunately the labeling on the wiring diagram and the board itself dont match which makes things a bit confusing but not impossible.
