Need Help! 6040 cnc PRT-E1500W vfd settings. - Page 2
Page 2 of 8 FirstFirst 12345 ... LastLast
Results 13 to 24 of 92
Thread: 6040 cnc PRT-E1500W vfd settings.
  1. #13
    Gold Member
    Jan 2005
    Default Re: 6040 cnc PRT-E1500W vfd settings.
    Quote Originally Posted by koolkleptokidd View Post
    i've tried asking them before but all they do is keep sending the same manual to me.
    They make this VFD, and don't have a very good manual, if you had it you would not be able to understand it anyway, I will work with you to get it running
    Mactec54
  2. #14
    Jul 2016
    Ive tried the settings and I cant get it to work, is there a difference between if it has the 800w of 1.5kw spindle?
  3. #15
    Gold Member
    Jan 2005
    No only the amp settings which I never found, now if you have the main Parameter settings in place, then there will be some control things we can try, Does the VFD power up ok can you do some photos, have you opened the cabinet
    What setting did you use in D031
    D032
    D033
    Try them all at 0
    Mactec54
  4. #16
    Jul 2016
    D032
    D033
    Try them all at 0
    ive tried them all and it turns on the spindle but it only stays at 144.6
  5. #17
    Gold Member
    Jan 2005
    Don't run it at that speed for very long only just to try the speed, this could damage the spindle
    Do you have all the Parameters I posted these must all be in place before running
    Have you switched the Spindle Mode Switch set to Manual on the front of the control Panel
    Mactec54
  6. #18
    Jul 2016
    I did put all the settings in place and I changed it to manual.
  7. #19
    Gold Member
    Jan 2005
    Another 2 to try just do 1 at a time and try it, it could be just one Parameter some where I will keep looking there may be something I missed, the manual I have is in Chinese and it has not translated very well
    Change D036=0 to Zero also
    D020=400
    D040=100
    Is your power supply 120v or 240v
    Mactec54
  8. #20
    Jul 2016
    D020=400
    D040=100
    Its 120v
  9. #21
    Jul 2016
    Its 120v
    I tried the d020 and d040 setting and it does the same thing.
  10. #22
    Gold Member
    Jan 2005
    So the trim pot makes no difference when you turn it, we will try some different setting that control this D031=5
    Do you have the VFD in the right mode for Running you may have to scroll to select this
    Mactec54
  11. #23
    Registered snq's Avatar
    Dec 2013
    I bought a 3020 with 800W spindle last week and thanks to this thread I figured out how to get it working.
    The manual states only to change D032 to 1, which did not work when trying to control it from Mach3, the motor simply does not start even if the display shows the right values and I do hear a relay click in the controller.
    Setting D032 back to 0 solved the situation for me! I have not had to change any of the other values other than D001 to 1 to allow changes to be made.
    Anyway, just wanted to thank you for the info and figured I'd post this for future reference, because I'm sure everyone else going by the manual will run into the same problem and will most likely end up on Google and hopefully finding this thread
  12. #24
    Gold Member
    Jan 2005
    Quote Originally Posted by snq View Post
    Could you look at all your parameters well up to 40, and write them down, as koolkleptokidd is still not running, his spindle turns on, but will not get up to speed, it could be just one parameter that is not set correct, and from what you have set, we may be able to see what is wrong
    Mactec54
