So he has the same connections as you do, but needs to change his Parameters settings, to suit his spindle, which is the important part, your spindle being the ATC model is most likely more robust than his spindle which he has not said what spindle he is using
The other thing he has to determine is if his VFD Drive has the Braking Circuit some models do not have it
